storing bike for winter
in a month or 2 im going to put my bike in a freinds garage for winter, what do i need to do for the bike to store it away? do i need to disconnect the battery or anything?
RE: storing bike for winter
I would put some fuel stabilizer in the gas, and ride it for a few miles to mix it up, and get it into the carbs. I always fog my engines with fogging oil, but it's not always required. You should also put the bike on the centerstand, so it doesn't flat spot the tires from sitting so long. And yes, I'd disconnect the battery.
Yep....
Fuel stabilizer in the gas..... Make sure you do an oil change before you park it, and after you get it out...... I would not disconnect the battery, but rather get a trickle charger/ maintainer for it... And at least start it once a week if possible, or once every two weeks. Just to help keep the oil circulated, etc. Would really help an extreme dry start situation come spring.
Spray most of the bike down with WD> keep all the wiring, rubber, etc looking good and protected.....
Wash and wax before you store it.
Just like CaddyDaddy said, put her on the center stand.
Lube the chain...
ANd most important.......... Give her a kiss before you put her down!!! lol
Lube the chain...
this is my first year with a bike but the guys i ride with a veterens and they love their bikes as much as i do! first i would put stabalizer and fill the tank all the way also put fresh oil in it and dont ride it and also change the plugs so they are fresh for next season and i would put a little more air in the tires but it dont matter to me because i will like to start the season on a new set anyway. my buddy also told me he does not disconect the battery on his and he has a gsxr 1000 2005 and his worked great when he went to start it. i live in canada next to detroit so our winters last at lleast 6 months if that helps were u are from. good luck
I too might be getting a 250 soon and will need to store it winter time also. Is it alright to start it every now and then just for a couple minutes and then park it again or would it be better to just leave it all winter. The reason I ask is because I heard that if you dont physically ride it oil is not gettin anywhere. Any feed back will help thanks.
ORIGINAL: kawasakifan700
It's really up to you how much you want to do, but it's a gamble!
Just go to an auto parts store, and ask for Sta-Bil. That's one of the most popular brands of fuel stabilizer. As for fogging oil, it usually comes in an aerosol can, and the Eagle brand is what I use. Or just ask the person at the parts store, and they'll hook you up!
