Riding the clutch?
Old 05-30-2007, 10:42 AM
AzzDawg's Avatar
Default RE: Riding the clutch?
Your welcome Toad.
And yeah Cyndia, Back off the throttle slowly and you wont get that jerky feeling. It is just the engine slowing the bike down.
Old 07-30-2007, 08:44 PM
apr43's Avatar
if youve never driven a stick shift car.. well lets just say you should probaly do that before a bike. but either way u gotta learn manual somewhere. when i first started i spent an afternoon in my driveway just practicing starting in first and slowly letting the clutch out and easing on the throttle, to find the "friction zone" (msf course word ha). its all about one or the other and a slight in between for when your changing gears. i had the same problem with my car. u just gotta find that area where it grabs andalways fully get off the clutch ones ur going.
Old 07-31-2007, 07:30 PM
Danase's Avatar
Sounds like you are in too low of a gear to me.
Old 08-02-2007, 01:46 AM
Nitrospaz19's Avatar
Hey cyndia,
I myself just started riding and barely ever drove a manual car. I am getting a little more used to it. Does ur always jerk when u down shift. Mine does and I dont know why anyone answer that?
Old 08-02-2007, 07:28 AM
Nitro, try blipping the throttle just a tad with the clutch pulled in just before downshifting. See if that helps your situation.
Old 08-02-2007, 11:57 AM
Kohburn's Avatar
if you are talking about cruising along in second gear then letting off the throttle "jerks" the bike - thats called engine breaking..
its not the bike that is being rough, its the throttle hand being rough. you have to make slow smoothdecisive motions when riding.
the reason the engine breaking force is so strong on bikes is due to the high gearing, the light weight compared to the displacement, and the high compression ratio.
once you understand the beast it will be easier for you to get used to how to handle it. then it becomes more enjoyable
Old 08-10-2007, 01:40 PM
Cyndia's Avatar
yeah the thing i was doing wrong was down shifting and letting go of the clutch immediately...... even when i wasnt down shifting, i was letting go of the throttle too quickly....
practice helped indeed
Old 08-10-2007, 06:34 PM
Notstock's Avatar
Tip: there is not any need to engine brake or to down shift through the gears. You should be using the brakes to slow or stop and then select the appropriate gear for your speed.
Example; if you are stopping you would select 1st gear after pulling in your clutch when the baking has you almost stopped.
If you are slowing from 65 mph to 25 mph you would be selecting 3rd gear after breaking to the slower speedand then ease out the clutch and add throttle to smoothly enter 3rd gear.
As always Practice Practice Practice.
Old 08-11-2007, 05:05 AM
m249c's Avatar
not, good advice. I keep having to remind myself that everyone doesnt drive a stick shift for a cage. i have been driving sticks since i was 16. so i dont think it will be as hard for me.
RayCour
07-21-2010 10:35 PM
deej
10-02-2008 09:58 PM
toad1025
06-29-2008 01:34 AM
JERSEY
04-23-2006 08:30 AM
shon
03-30-2006 09:05 PM
Quick Reply: Riding the clutch?
