RETORFIT HEADLIGHT
Will you be using a different upper fairing to fit this headlight? If the shape of this retrofit headlight brings the 250's appearance up to date, I'm sure a lot of people would be very interested.
ORIGINAL: markmeinteil
ORIGINAL: mnosbor
Id be interested, just keep in mind that the electrical system only has about 55w to spare if you are adding bulbs.
ahh as I was looking for headlights for batang's retrofit,I came accross this site.
I'll be doing the retrofit with a bixenon G35 projector...I'll swap lenses with the e30 for a sharp cutoff, blue colorband and more output(wider).
I just purchased some headlights and will be using murano shrouds.
Method:
- I will be sanding out the headlights to make them clear.
- fitment will require modification
- The projector must be as close as possible to the outside lense of the headlight housing so there will be more light and have greater foreground limiter.
- custom murano shrouds will be used for a unique look
- This will be my first bike retrofit lol
Method:
ORIGINAL: striker_1818
Method:
Method:
Good luck
