replacement radiator for 2000 ex250
Old 04-24-2013 | 07:34 PM
Thomas101's Avatar
Default replacement radiator for 2000 ex250
I have a year 2000 ninja ex250
I need to buy a replacement radiator and I am wondering if anyone can tell me how specific I need to be when purchasing this part.
Will a 250r radiator work? or a radiator from a different year?
Thanks for your help
Old 04-24-2013 | 07:58 PM
Thomas101's Avatar
just to be more specific the bike is a zzr250 (ex250h11)
Old 04-25-2013 | 01:21 AM
http://en.wikipedia.org/wiki/Kawasaki_Ninja_250R
EX250-H - This model came to Canada as the Ninja 250R between 2000 and 2002, after which it received a new name: ZZR-250, in line with the -H model's name elsewhere in the world, where it had existed since 1992. This motorcycle has parts in common with the -F model, though it shares the same engine, albeit with different casings. It sports a lateral aluminum frame, a different fairing (designed to make it look sportier), larger 17-inch wheels, an adjustable rear shock absorber, adjustable brake and clutch levers, a smaller drive sprocket, computer-controlled timing advance, and a revised electrical system. It also featured a smaller carburetor, & slightly different compression ratio, both of which were designed for quicker revving and slightly higher top end power. However, these upgrades came at a 6kg weight gain
found on the wiki online.
I would think then that all first gen 250's radiator would fit for your ride.
tstauder
06-02-2011 01:48 AM
BikerChick
Ninja 250R
12-05-2008 03:58 PM
Alex
09-04-2006 02:10 PM
lucas8888
04-09-2006 02:37 AM
Tiny250
08-17-2005 04:22 AM
Quick Reply: replacement radiator for 2000 ex250
