New Rider - Shifting Question!
Hey everyone. Thanks for the replies. Although it's a 2007, it's been well broken in with 11,200 miles on the odometer. The first guy who owned it used it as his sole means of transport so this bike's been well ridden!
Upshifting based on the tach and the feel of the bike makes a lot more sense than upshifting based on speed. Thank you for that clarification.
I'm trying to work on rev matching while downshifting. It's a bit tricky because it's against my instict to brake and rev the engine at the same time! I suppose it just takes time.
Thanks again!!
Thanks again!!
****ing down to get extra acceleration, just shift and pin the throttle as you let the clutch go.
If you're new to bikes, you probably know that most braking is done on the front brake, because of the weight transfer effect, but you may not know that that effect diminishes as you slow, so that by walkiing speed there's more grip from the rear tyre than from the front. That's where you should start to ease off the front brake and come to a stop on the rear to eliminate the small risk of a front wheel lock up - especially on on a poor or wet surface. If you lock the rear wheel you should be able to control it. If you lock the front you'll probably fall off.
Rob
btw - the asterisks are on the word 'shifting'. Did I miss an 'f'? lol
IGonzoI
07-07-2009 04:21 AM
