Have a miss when engine is cold....
When I am warming up the bike you could hear the mis in the exhaust. But when the bike is warmed up it's fine and never misses at all. 04 with 7000 miles on her.
RE: Have a miss when engine is cold....
Does a miss sound like a small poof sound? When I first start my bike cold I get 3-4 small poofing sounds inbetween the normal sound all close together than never again. If this is what you are experiencing than I think it's normal.
A "poof" to me is incomplete combustion. Kinda similar to my past CR480 when it wanted to jack my **** over the handlebars after it got into the compression stroke. Poof was when it was not enough into the compression stroke and could not build the a/f and combustion. Not sure if this made since though.
ORIGINAL: JaBr1884
ORIGINAL: mnosbor
Im pretty sure what your hearing is normal, Ive heard mine do the same. You do want to make sure the idle rpms are set correctly they should be between 1200-1400 rpms. The 250 doesnt run as well cold so I dont make any judgements or adjustments until the bikes warmed up.
boarders09
05-13-2020 03:06 AM
Israel-klx250s
03-04-2012 08:33 AM
