Gas in oil
Gas in oil
Hi I am new to this site and new to motorcycles. I have a 96 ninja 250 would only start and stay runnin with choke on. Bike has sat for like 2 years before I got it. Drained the gas out went to change the oil noticed oil smells like gas. Can anyone suggest what the problem is? This bike only has 3700 miles.
Yep -
Clean out the carbs. Main jets might well be gummed up if you can't get it off choke.
In use, gas in the oil can be caused by cool running - Rich mixture from the choke and poor ring seal because the motor isn't up to temperature, so a faulty thermostat or a lot of short cold start journeys can cause this problem.
You might have gas in your oil because you've been running it with the choke on. Sort out the carbs, do an oil change, and see what happens.
Rob
Rob
