Funny!
Old 03-20-2008 | 05:53 PM
specterunseen's Avatar
Default Funny!
Courtesy of Ninja250 forum: ABOUT RIDING ON THE NINJA 250 for a long distance trip:
You are very brave to attempt 150 miles non-stop on a toy bike. For such adventuring, here are some of the secrets of the 250 Riders Club vets. Well, at least the ones with the nerve to attempt what you're about to.
- switch to reserve at the start, before you get on the highway. This avoids fumbling around in what might be high-speed, heavy traffic.
- some drivers might disrespect such a small bike. One easy way to show them your confidence is by riding with your left hand in your jacket pocket, just like the cruiser riders do.
- ride the whole distance tucked in behind the windshield. Your teensy motor will need all the help it can get, especially uphill.
- keep both knees wide out, to increase side-to-side inertia. Due to the skinny tires, the bike is unstable at high speeds.
- don't wear earplugs. With that much strain on the bike something could go wrong, and you'll want to be able to hear it at the earliest possible moment.
- if you see a truck coming the other way, pull over onto the shoulder and slow down to a minimize wind blast that could send your lightweight bike snakey under you. When I see two or more trucks coming, I try to stop.
- don't make the trip if it's raining. There isn't enough bike weight to keep the tires in firm contact with the roadway, so it's way too easy to hydroplane. Add a crosswind to the rain and a Ninja rider is soon in real trouble.
- don't bring anything with you. The suspension won't cope with it when the high-speed airstream over the windshield forces the bike down, and the extra weight will kill the acceleration if you have to pass someone.
- always keep a tiny bit of pressure on the rear brake. This keeps your rear brake light lit, so cagers coming up behind will notice you sooner and not nearly run you down when they come up fast. Bigger bikes with wider rear tires have almost double the visible area from the rear, and don't need to do this.
- if you have to urinate, pull into a side road so you can do it on the engine. That's better than having the cylinders sieze up from overheating, which they will do if you're over 120 lbs. wearing your gear.[/align][/align]
ALSO:
Until the engine warms, and most times after, it's prudent to do a bobsled start. That is, run next to the bike until you're above 5 mph. Then jump on and go. Failing to do this can easily burn up the clutch and waste the engine.
Also, lots of us coat ourselves in suntan oil, as this makes us slicker to the wind, thereby reducing the overall drag on the bike, and increasing out top speed to 57, even 58mph!
Some of us are more bold, and we've carried hooks and chains with us. We use these to briefly hitch a ride on the back of passing cars, when caught behind semis. These little bikes aren't good at passing without assistance.
Lastly, during any extended run, carry with you a spray bottle full of water. When it comes to the lil Ninja, this is the other facet of water cooling. As you travel, roughly every 3 tenths of a mile, mist a little water on the engine. While to the amateur this may seem like an indulgence, the more well traveled of us know it's truly the only thing standing between us and a flat bed ride back to our homes.
Cheers.[/align][/align][/align][/align]---------------- courtesy of forum @ ninja250.com[/align][/align]
Old 03-20-2008 | 06:25 PM
markmeinteil's Avatar
Default RE: Funny!
Haha! "helpful" advice, there. Although, I think I'll take my chances doing it my way.[8D]
gotrice
07-26-2006 02:58 AM
ZX12Rider
Joke section!
11-22-2005 09:22 PM
ryninger
11-21-2005 07:02 PM
shon
11-17-2005 11:20 PM
petezzr
09-12-2005 07:23 PM
Quick Reply: Funny!
