Bike back up, two problems though
Old 06-13-2007 | 07:51 PM
Mott Power's Avatar
Default Bike back up, two problems though
So i took her out for a born-again virgin ride and everything was going good, first little thing i noticed though was the airbox is hitting the top of the rear shock, not sure if missed some small bolts or what, not sure where to pin-point that problem either, but the second is i've noticed a squeeking noise when i go over bumps or little inclines on the road, but i can't pinpoint that either, i sounds like its coming from the rear shock or the swingarm axle.... maybe rear wheel axle? i dunno, anyways its annoying and makes it sound broken, like a loose pulley on a car almost, i'm gunna try to get out later and put her on the center stand, see if i can't find the problem, but any suggestions?
quick pics i took in the link
http://s201.photobucket.com/albums/aa3/MottPower/
Old 06-13-2007 | 08:48 PM
1lowGMC's Avatar
Default RE: Bike back up, two problems though
looks good, I like it the street fighter look.
Old 06-14-2007 | 12:07 AM
markmeinteil's Avatar
Turned out nicely I must say. What size rear tire do you have on it?
Old 06-14-2007 | 04:40 AM
mnosbor's Avatar
Dont know without seeing it, but Im betting if you fix the bumping the airbox you can fix the noise. do you have a stock shock?
Go to www.ronayers.com and look at their parts microfische to see what your missing.
Old 06-14-2007 | 06:02 AM
Mott Power's Avatar
got it! seems as though it was the fuel tank, one of those rubber bushings fell off at some point and i guess i didn't notice, put some duct tape around it real thick and everything is good! i thought for sure the rear shock was hitting because i felt a nice jolt sometimes but i went out tonight and felt nothig after the duct tape fix.... weird
mark, i'm using 90's on the front and rear, seems to dip into corners much easier, i haven't been able to take her to the edge much but i'd like to find a nice road which i can, nice tires for how much i got them, nice and sticky
sup_uni
04-04-2018 03:27 PM
Phil2801
Ninja 250R
04-04-2018 03:17 PM
GrimmDraco
05-14-2008 08:16 PM
smokin25
10-01-2007 06:14 PM
kazerotor
06-25-2007 08:29 AM
