Already searched can't get lowered...
Old 07-08-2008 | 05:11 PM
squidremz's Avatar
Default Already searched can't get lowered...
Looking to drop my girls 2006 250...she’s way short (coming in at 5’). Bought some links from flea-bay but go to install and the links are same size as stock. They both measure 7”. Add claimed a true 2” drop but I’m not seeing it. No instructions but the way I dropped my F4i was simply : remove stock linkage and putting in the aftermarket. Piece of cake.
Are you supposed to remove the dog bones completely? Took off the shock and that can’t adjust at all so any ideas. No one anywhere has a DIY...which I will do once this get figured out. [:@]
Old 07-08-2008 | 05:48 PM
Kohburn's Avatar
Default RE: Already searched can't get lowered...
so all the holes on the new links are the same as the stock links?
Old 07-08-2008 | 06:22 PM
squidremz's Avatar
Yes sir. These are not adjustable links. I honestly think the seller is really mistaken with his product but I'm checking with the guru's that be KF first for input.
Old 07-08-2008 | 06:26 PM
squidremz's Avatar
Should be connecting like this correct? Again remember these are NOT the links I purchased...may end up having to buy these.
Old 07-08-2008 | 06:42 PM
Kohburn's Avatar
try for a refund then - if i remember right they need to be longer than the stock ones to lower it.
frye22
09-10-2009 07:47 AM
JonnyD
07-16-2008 08:22 AM
deej
06-03-2006 07:22 AM
Colo_636
05-28-2006 09:44 PM
devestator_x
10-05-2005 05:46 AM
