Is the 250r right for me?
![Thumbs down](https://www.kawasakiforums.com/forum/images/icons/icon13.gif)
I am considering getting a 250r. I am a new rider, I have been on a couple 600s before but never more than a few hours and have never owned a bike. I am 6'1" and 179lbs, I was wondering about my size on the bike as well. I also would like to know if it is worth doing any modifications to this bike. I was thinking maybe a different exhaust. Thanks.
Forget it....get something else. See my other post.....carburetors are a pain to repair and maintain. They have lots of mechanical parts that will fail. Sometimes running in the mid 100s to repair/clean. I just paid $450 for a professional cleaning.
Get fuel injection. If you run into a problem with a 250, you will never get the right answer from anyone cause no one cares about carburetors or the 250 anymore.
ouch joserpm, I replied to your other post as well. Once you understand how a carburator works, then maintaining them is not bad at all. Sorry to hear about your bad experiences with them.
I'm just waiting for someone to tell me 'wow, $450? I know so-and-so that would do it for $20'. Or 'I can tear the bike apart, clean the carbs, and put it all back together in 10 minutes'. The 'super mechanic'. Maintaining carburetors is not bad....is HORRIBLE. Tiny little parts that cost $20 or more to replace. Fuel injection is the way to go. That's why cars have them, and newer bikes too. They run clean, they don't choke you to death with the smell of fuel fumes, and, again....less mechanical parts to worry about.
Well, at least I learned one lesson. Forget buying a classic VW Beetle to restore then. And when my lawnmower dies.....It's gonna be replaced with an electric one. ZERO TOLERANCE TO CARBS. PFFT!!
^^LMAO^^ You must have the money to blow. If you didnt, You could of learned how to do it in 3 to 4hrs & Less then $40. Buy A Manual.
edit: I am not a mechanic either, but I like to tinker.
Carbs are easy to maintain, and apart from the float chamber have no more moving parts than the throttle body of an injection system, which also usually has stepper motors and position sensors, not to mention injectors that are electronically controlled and need cleaning or replacing. Add in the inlet pressure sensor, inlet temperature sensor and the ecu, plus the O2 sensor needed to monitor fuelling on a closed loop system and you have a much more complex system that costs far more to fix if it goes wrong.
TBs need synchronising, btw - just like carbs.
Read some of the forums on FI bikes and look at the complexity of getting correct fuelling. Modify the bike, change the exhaust for example, and you're probably looking at buying a Power Commander and spending hours trying to tweak the map. I like FI systems, but for ease of maintaining them, give me a carb any day.
Rob
Rob
Rob
Rob
Point proven. It can't be done with $40.
