250R Not Starting
250R Not Starting
Hey guys, I am having trouble starting my bike. I havent ridden it for about a month and when i tried to start it the only thing that happens is it keeps cranking. Now when i turn on the choke while im cranking it it starts i let it warm up for a good 2 minutes and throw down the choke and it just dies. Even with the bike fully warmed up it wont start unless the choke is on. Any ideas whats wrong?
I am at around 560 miles and have not had a tuneup or oil change.
Thanks in advance
James
Thanks in advance
James
RE: 250R Not Starting
Dirty carbs? Not likely. My guess is that between possibly bad fuel, and the seasonal temperature change (if this applies to you) it willcause the bike tonot run well. Syphon the old gas out andput some fresh gas in. If it still runs poorly, you may just need to adjust the idle. (Bump it up a little.) When it gets cold outside, sometimes motorcycles don't like to idle very well.
