small drain plug - 2006 kx250f
Old 01-04-2008, 10:51 PM
p2thec's Avatar
Default RE: small drain plug - 2006 kx250f
i flushed it too many times to count before riding it. The peice is so small it may have came out and i didn't even see it. anyhow i've ridden it a bunch and she's still a dragon.
Old 01-05-2008, 04:16 AM
kx slaughter king's Avatar
was it running when you flushed it out?
and i agree with deej alot, running with metal chunks flying around your gearbox can shred gears and be a bearings worst nightmare. put the bike up on a stand, put it in gear and listen to the gearbox and flywheel housing. if you hear random ticking or taking you could be in some trouble.
Old 01-05-2008, 01:04 PM
p2thec's Avatar
no man i flushed cold many times before running it. i then ran it easy on the street for a bit and droped oil and filteragain 3 times. i ran the snot out of it indoors and it runs great. I think it came out, or is caught up inan oil gallery or a screen.
Old 01-05-2008, 04:47 PM
well for your sake i hope it came out. if its not making any abnormal noises im most likely did, and sompething like that wouldnt really do anything to the perfrmance until it got stuck between two gears and jammed up the bike. but if its really that small the gears could just crush it... either way if i were you id change my oil every ride. to save $ run the stuff you just drained through from the bike through a fine sifter then back into the bike for the next ride, rather than buying fresh quarts everytime.
mark1980ep
Ninja 500R
03-26-2011 02:07 PM
hbavaro
KX250 & KX250F
09-17-2007 03:37 AM
hbavaro
09-16-2007 07:28 AM
stellar_d
06-18-2007 10:09 PM
Notstock
03-08-2006 03:26 PM
Quick Reply: small drain plug - 2006 kx250f
