New rider with a bike problem
Old 06-20-2012 | 01:58 AM
lukashanson21's Avatar
Default New rider with a bike problem
I'm pretty much brand new to riding and just picked up a kawasaki kx250 and as I was riding around getting use to it the throttle went limp. The handle just lost all tension and the bike sits at idle when started so I took the cover off the spool-thing on the handle and the throttle cable can't be pulled out anymore or pushed in any. I'm guessing I broke the cable. What do you guys think?
Old 06-20-2012 | 05:24 AM
Brieninsac's Avatar
Look at your carb, make sure both throttle cables are seated in the bracket.
Old 06-22-2012 | 03:00 AM
Sorry it's taking me so long to reply, I've been busy with work. I found out the bike is a 96 and I traced the cable back to the carb and I unscrewed the top where the cable goes in and inside there was a spring but no cable going into the carb. This is the first time I've ever worked on a dirt bike so I have no clue what I'm doing lol
Old 06-30-2012 | 04:19 PM
Thanks for the help turns out the throttle cable was only pulled off the carb slide.
IGonzoI
07-07-2009 03:21 AM
DaddyTrox
05-14-2008 06:45 PM
jvmvsenna
09-22-2007 06:10 AM
flatblue636
10-24-2006 01:24 AM
gotrice
08-06-2006 07:48 AM
Quick Reply: New rider with a bike problem
