Idle Problems
RE: Idle Problems
I had the same problem with my bike until i screwed in the idle screw all the way in, and after i started it i adjusted it to where it was just right. Also about that rattling sound, i herd it could be the power valve hitting the piston, and i'm not sure if its because i need a new top end. I've herd that sometimes the c clip could pop off, from where the piston connects to the connecting rod, and scrape along side of the piston. I watched a video on youtube of a guy with the same make and year bike as you and it was making the same rattling sound. Have you ever ridden your bike in the sand?
RE: Idle Problems
Does the rattling your getting hit with every stroke. on my bike its a constant light click on every stroke. I did talk to my boss about the noise and he said that he was pretty sure it was normal as far as he knew. i haven't had the bike in the sand before. also, do run your bike on pump or racing gas?
RE: Idle Problems
I had the power valve hit the piston on my old bike and trust me you can hear a horrible sound for only a few seconds until you top end is done. If your hearing this al the time theres no way your power valve is hitting your piston.
RE: Idle Problems
How does your power valve hit your piston?.....unless your powervalve is very dirty from carbon build up...... my 98 doesnt Idle at all unless i blip the throttle.....never has and it runs like a stripped *** ape....crisp throughout the powerband from low to overrev(what little it has) so i guess my question is what do you mean it wont idle?
Born2Drive4Ever22
10-25-2007 03:50 AM
