Grip Glue
RE: Grip Glue
Hairspray does work as long as it doesn't get wet. It is water salable (or however you spell it)so, when you get a tarein your grip or if you get water in from washing it could loosen it right up. Just use the glue, it's made for it.
RE: Grip Glue
https://www.kawasakiforums.com/m_104783/tm.htm
check that thread out.... lots of good ideas... and if hairspray is water soluable.... not good on a dirt bike, i go through water alot.....
RE: Grip Glue
Iknow not alot of people are strong believers in this but gasoline works great, dont use to much, i will eat through your grip, just swish a little in the grip, slip it on, and let it set in the sun, the gas evaporates, and the grip is pretty much vaccum sealed onto the bars, never slipped on me
