dang and blast dat clutch!!!
has anyone tried fitting a clutch from a l8r year kx250 to a h2 1991? is there a difference in the shaft between 1991/1992? having problems getting hold of clutch basket and hub, its a b*tch. cheers an beers all round!
RE: dang and blast dat clutch!!!
I hear ya, Had a 92 kx250 and the basket was really notched up. I just took a dremel and filed them down a bit. I think they are the same but not 100%. Was going to buy a Hinson but way too much cash.
thats the problem, the basket has hit the dust with two broken teeth and i was hoping for an alternative to the open wallet surgery that is required for a billet jobbie. must be a mobike mechanic somwhere who can give me advice on this. might try kawasaki directly but wont be holding my breath. happy riding everone and remember, you only die once so make it a good'un!
I busted off one of the4 screw posts off on the basket because like and idiot I stuck a scew driver between that andteeth to get the main nut loose.duh!...see previous post. Anyway I took the basket to a radiator shop and he welded it back on. Cost only 25 bucks! Was good as new. Maybe try get a welded and see if it stays and if it don't , there's good ole' ebay.
kewl, i was pondering gettn sum aluminium wire for my mig welder and trying that but didn no if it wood work, iv never welded aluminium b4.i jus got this bike, bot if off ebay wit the seller saying it jus nneded piston an a barrel re-plate. it duz but he never mentioned dodgy clutch. still, on the good side it did av a new ohlins shocker fitted (complete wit ohlins sub-frame)a month before i bot it and everyfn else seems to be in good nik, well worth 400 kwid. fink i'l go for a re-sleave wen iv got clutch sorted. cheers amigo!
Sounds good, let me know how it works out. I see your from Scotland, that's got to be some sweet riding. My brother was in Edinborough for a week and showed some amazing photos. Being half Scotish and half Irish I'd like to get there one day, maybe ship the bike over and just travel around. But until I come into a bunch of money I'll be here! Cheeers!
