92 kx250 and 91 kx 250 parts interchangeable?
Old 07-06-2007 | 12:50 AM
tramatbay's Avatar
Default 92 kx250 and 91 kx 250 parts interchangeable?
I have a 92 kx 250 and replaced the front forks with ones from a 91 kx 250. The front brake mount on the fork is 2 1/2inches center to center on the 91 forks. The mount on a 92 is larger, about 4 inches. The front brake caliperassembly numbers match for a 91 and 92. The only difference from the parts finder listis the front disc and front caliper holder assembly (figures). Does anyone know if the 91 front caliper holder assemblywill match the 92 front caliper to mount to the fork? I thinkwill but could not confirm from local kaw dealer.
Any help will be greatly appreciated,
keith
Old 08-26-2007 | 06:43 PM
kx slaughter king's Avatar
Default RE: 92 kx250 and 91 kx 250 parts interchangeable?
88-92, 93-00, 00-04. theyre all the same bikes and most of the parts should be interchangealbe no problem.
Old 10-25-2007 | 01:57 PM
KickassKX's Avatar
The reason the brake mounting is bigger on the '92 is beacase 92 onwards have dual piston calipers
Old 01-02-2019 | 06:07 AM
bt1985250's Avatar
Default Help
Ok,I am in need of all the wiring, CDI, coil zetc for my 91, can't find ****, will 88,89,and 92 work? Thanks
Old 05-14-2020 | 02:42 AM
Chase Anderson's Avatar
Default 91 Kx 250
Will a crank from a different year work in a 91 kx250
bennythejet33
10-02-2015 04:18 PM
pontakoj
KX250 & KX250F
10-23-2013 07:57 PM
Kx250 92
KX250 & KX250F
12-19-2012 04:25 PM
dirtridr
KX250 & KX250F
02-20-2008 01:13 AM
bansheedave
09-24-2006 04:55 AM
Quick Reply: 92 kx250 and 91 kx 250 parts interchangeable?
