So, I'm going to post things that I want/will do to my KLX300R that manufacturer's don't have available.
It's not like I'm creating things that are new, but making things fit.
also, I will post things that I have found that could help other poeple.
1. Acerbis Disc guard. I have milled the fork side of a mounting bracket .100" down to accommodate the .555" factory spacer to the front alxe/wheel bearing, and making a new spacer. https://www.acerbisusa.com/p25637-x-...%2B%2523ef7c00
2. I talked to Trail Tech and the Endurance 2 computer fits, the just haven't updated their website yet. #202-119
The machine shop just made my spacer... in 4 minutes!!!! The Acerbis mount is for a 2005 KX250.
Ready to mount my Acerbis disc guard!!! Just a reminder... I took off .100" off the fork side of the Acerbis mount, then used the spacer.
I didn’t want to use the rubber straps supplied with the headlight, so I bought a 36” x 1” aluminum strip and some 5/16” grommets to make a bracket. I also bought 2, 90 degree brackets to mount the top of the bracket and will utilize the 2 post on the triple clamp for the bottom.
Yes. In NH, directionals are not required. Thx for the complement!! Just trying to share info that I'm finding.
I do the same with new ideas I come up with, so I like to see what other riders do to personalize their bikes.
There is almost NO information on my SM because it's a new model. No factory shop manual. Not even an owner's manual. I'm only the 3rd one to dyno test it.
