Yoshimura ST-1 Cams
Old 08-24-2018, 11:56 AM
outrecording's Avatar
Ok, that was quick. Yoshimura just lists the specs. I’m not smart enough to know what those numbers mean. Maybe someone here can speak that language
And I found this on an eBay auction from Oz. Looks like it was (probably) translated from Japanese.
■Product Description:
Corresponding Engine Model Type: LX250DE
Type: ST-1
Maximum Lift (mm): IN 8.80mm/EX 9.20mm
1mm Duration (Degrees): IN 234-degrees/EX 238-degrees
Standard Tappet Clearance (mm): IN 0.20mm/EX 0.20
IT achieves approximately 18% lightweight than the STD camshaft by ion-nitriding surface treatment by cutting the camshaft itself. It eliminates the flaws that are shortcomings of bore up vehicle, and it is the performance that will rise comfortably up to the high revolution range from YOSHIMURA original profile.
* The indicated cam specification is calculated from the camshaft design value.
*There might be some discrepancies by lot due to manufacturing factors.
* Though bolt-on installation of ST-1 is possible, if you require further accuracy, we recommend you to readjust the valve timing.
Sound slike its saying it’s helpful for those with a big bore and has a more uniform powerband?
Old 08-24-2018, 03:44 PM
TNC is offline
OP, I'm pretty positive that the model they list will use the same cams as any KLX that's been produced. I would have a question about FI models vs. carb models. I might wonder if those cams are more adaptable to one or the other, and/or if the FI models might have any fueling issues with those cams. Is your KLX an FI model? I notice that quite a few Asian market KLX's had FI well before they showed up in the U.S.
Old 08-25-2018, 06:26 AM
Yes TNC, you’re correct. We have the FI klx here in Taiwan.
I believe the d-tracker was carbed in the beginning and eventually switched to EFI; looks like around 2008 with the D-tracker-X.
Yoshimura didn’t list the year but found this on another site:
Fits: Kawasaki 250SB '02~'05, D-TRACKER '98~'05
So yeah, probably designed for the carbed version.
Old 08-25-2018, 04:26 PM
TNC is offline
Yeah, it doesn't mean it won't work, but it might need a tuner to optimize it to your current bike. In your market area do you guys have an FI tuner for the KLX? I'd bet someone in your area knows this and how it might work with these cams or other aftermarket cams.
Old 08-26-2018, 02:13 AM
GBAUTO's Avatar
From what I can see on webcams site, it looks like it may work. It's a bit wilder than the webcams I'm running. If it's fuel injected, you would need to remap but a carb model should really wake up.
Old 08-26-2018, 02:05 PM
Not much for tuners where I live. At least not for the klx. Our bike isn’t too popular here, possibly cuz of the seat height...not sure. More riders gravitate towards the CRF for a dual sport. But by and large, scooters are king.
I use the EJK with my big bore. Not sure if that would cut it for “tuning” in this case or if someone really would need to get into the computer and adjust from there?
Oldboy
02-28-2020 03:34 PM
Richard Avatar
06-28-2013 08:15 PM
steggstlr
11-30-2010 05:09 PM
GaryC
02-17-2010 12:31 AM
biglg7
04-06-2007 07:56 AM
Quick Reply: Yoshimura ST-1 Cams
