Yoshimura RS-2 Slip On Review for 2018 EFI KLX250
#31
We gettin closer.. Now drag down your stock silencer and stick that thing on the stock nipple.. That is the only way we will know, absolutely / definitely, how the Yoshi is designed to interact with a header..
You should now have a little improvement in power levels and throttle responses - certainly below 7000 rpm - and a little more power 7k - 9k...
#33
Ok, great.. Now that you/we know the Yoshi nipple, please, if you can, get us a measurement on the stock silencer nipple. I am not able to do this..
While I am quite sure it will be the same, we don't know until we know.. Then I can add the Yoshi data to the Exhaust sticky.
#36
Also, now you can get a FMF slipon for the PB and sell the Yoshi. Results will be a boost in power levels 6.5k rpm to 10.5k rpm, but with a loss of power levels below 6.5k rpm from what you have now..
What you have now is superior power off idle to about 7k RPM - after which your power levels will begin to drop off until, at 9k rpm, you are "done"..
#37
Here is the beauty of your current situation:
With the dynojet PCFC, you will be able to quickly adjust your WOT( wide open throttle) fueling curve while on a dyno. This is all that is important.
You can adjust the low and mid ranges yourself to suit your preferences..
Create a relationship with a local dyno shop and you can quickly compare/contrast your exhaust components (if you acquire an FMF slipon for that PowerBomb) as well as lid-on vs lidless power curves..
I am thinking that once fueled correctly with a lidless airbox, your current setup (stock bike + Yoshi ) might be able to do 1st gear power wheelies (with some experimenting on the RPM point before snapping to WOT).. like the wheelie vid below on my signature line..
#38
dyno turner and airbox removal
Hey cool suggestions. I have a klx250s 2018. I just put on the Yoshimura rs2. I guess I now have ‘lean pop’. I knew it would be off fuel wise. Do you have a link or could you point me in the direction towards the proper tuner? Does this plug into the bike? And do you have suggestions/precautions and/or tips in removing the airbox lid? Thank you.
