yeah yeah I know more mod talk...
Well the more mods I look at the more I realize I probably won't get the big bore kit in till this winter,but in the meantime I am still gonna put on some of the more basic ones like a FMF powercore 4 and some fatbars and handguards and all that fun expensive stuff,seems like some people say that no jetting is needed for the fmf's and some people say otherwise,whats the truth? I get the feeling that maybe you don't need the rejet if you don't fiddle with the airbox cover but I am not sure.My other question is,if I install 20mm moose universal standard to fatbar clamps and a cr- hi bend fatbar will I need longer cables or anything like that or do I have enough room to work with?thanks in advance for the replys.
Hunterman.
Hunterman.
Just adding a pipe, required me to mess with the A/F screw, that was it.
I have CR-high bend (non-fat)bars with no risers and I had just enough cable to do it. Adding risers soon, waiting for +2 cables. I could use +1 as it is now(w/o risers), but with enough careful tugging and routing I could get it to work. If I cut the bars to stock width, it would be fine, but I like the width.
On my 09 the powercore4 was ok even before I messed with the af screw. Although it would help to back it out some from stock. I would not mess with the intake side without a rejet. The slip-on alone was the single best mod from stock I did. I ran the 13 sprocket up front for awhile but it's back stock now as I ride alot on road.
Great stuff! thanks guys for the info, also thinking about the 13t sprocket and just wondering,does it need any different of a chain length or can you simply loosen up the chain tension, replace the sprocket,replace the chain and away you go?
Thanks.
Thanks.
If I was going to do just one thing it would be the BB351 thing.
