Yamaha TW 200
RE: Yamaha TW 200
2004, and they got it for 2500, very clean, and 1500 cheaper than a new one.
http://orlando.craigslist.org/mcy/187694053.html
RE: Yamaha TW 200
ORIGINAL: klxcrazy
Deej, this is off your subject, but for your future info, i say future because you havent had the bike long enough to experience the not starting part of the tw200. if you let this bike set for more than a week or two without starting it, it probably wont start. same with some other Yamahas in the smaller cc. if you have this unpleasant experience, drain some gas from the bottom drain on carb, and it should start. my dad has one that he doesnt ride very often, so every time he wants to ride it, we have to do the drain the gas thing. Yamaha has no solution for this problem. they blame it on bad gas. same gas in honda and kawi starts no problem. good luck, hope this helps.
My XT225 is the same way. You must always make an habit of always turning off the petcock as soon as you roll into the garage so to prevent any extra gas from going into the carb.
You're right. I have no problem whatsoever with the KLX. It's actually the easiest starting carburated bike I have ever owned, hands down. It starts the instant I push the button. I can turn off the choke immediately after I start riding. And the bike is 100% stock!
BTW, deej, that's a real sweet deal your buddy got on the TW!
RE: Yamaha TW 200
ORIGINAL: FM_Thumper
ORIGINAL: klxcrazy
My dad still rides his TW200 once in a while, but, after I bought my '03 DR200SE, he liked it so much, he found himself a mint condition (less then 40 miles) '99 DR200SE that was used for a local Motorcycle Foundation Course and now rides that almost exclusively.
We have both been talking about getting the KLX250S, but, neither one of us want to hassle with lowering the darn things. =)
The XT225 had a bit more get up and go and I liked the 6 speed tranny, but, the DR200SE is a little bit lower and has a much better seat. Plus, I don't have any issues with starting it, even if it sits for months at a time.
The TW200 is a fine little bike, as well, though, with that big tire, you have to watch the slippery stuff, like muddy logs and such, it will tend to slide out from you easier, than a more traditional dirt bike tire, due to the lower weight per square inch ratio. Though, that works as an advantage in other terrains, like sand.
Laters,
CRT_Leech
banjobart
10-31-2011 03:25 PM
momonapua2003
12-29-2005 02:46 AM
