XR 650L sprocket 13tooth
I have been talking to Alicia with http://www.gomotoriders.com as she is willing to ship to Canada USPS. We’re trying to track down the correct part number for the Honda XR650L 13 tooth front sprocket. Here is a link to the part she has listed…
http://www.jtsprockets.com/52.0.html...el_uid=4078&p=
But to me that looks like the last two digits of the part number indicates it is a 15 tooth. And that part number is different from this one posted here.
https://www.kawasakiforums.com/m_67734/tm.htm
Man this sucker is hard to get, freakin Canada eh.
RE: XR 650L sprocket 13tooth
it says
Front Sprocket: JTF 1309.15
Rear Sprocket: JTR 301.45
Recommended Chain: : 520 / 110
Front sprocket available in: 13, 14, 15 teeth
Rear sprocket available in: 45, 48 teeth
its available in 13 14 or 15, i would imagin that the last two digits change depending on how many teeth you want... just a guess though.....
Ems that is exactly what the last two digits represent. I could not have said it better. I hope that helps Mark. The picture is representing the stock gearing and it is listing your options.
ORIGINAL: EMS_0525
it says
it says
im a good educated guesser! thanks.
ORIGINAL: suprakawigrl
ORIGINAL: EMS_0525
it says
it says
This is true too, that is where the confusion lies, Mark do you want a front sprocket for a KLX250 or for a XR650L? I am not saying they do not interchange but my books do not indicate that they do...I can get either part number for you.
ORIGINAL: a16tony
The correct front for the KLX250S is: JTF516.13 or .14/.15
Hi Guys
I just got a 514XK-13----------13 Tooth CS - From Sprocket Specialists for my klx 250. Which way does it get installed? Raised edge with writing towards the engine or away from the engine. I installed it with the writing and raised edge facing the motor I hope this is correct. It seems to fit ok. Anyone installed one of these sprockets?
ORIGINAL: a16tony
For the XR650L, just because I know for sure that it will fit.
LordVngr
09-24-2006 06:03 AM
