WTF is with these Harley riders?
#171
RE: What is with these Harley riders?
ORIGINAL: deej
brother-in-law needs a new anchor for his fishing boat.......
ORIGINAL: markmeinteil
Deej, you wouldn't know what to do with the bike on the far left![sm=icon_rofl.gif]
Sorry, I had to throw that in.
Hahahaha!
#174
My neighbor has a 06 Road King. He said he always wanted a Harley.
In about 9 months time it been in the shop for,
2 - radios
pin hole in rear rim
speedo stoped working
barrel separated
exhaust loosened
fork seal leak
cam flatened
Now he is thinking about geting another Road star.
2 - radios
barrel separated
exhaust loosened
fork seal leak
cam flatened
#175
ORIGINAL: FM_Thumper
Here is the other side view.
BTW, deej, these are the cheaper non-S version($11,495).
#176
the duc is extremely naked - doesn't look like its got much of a fual capacity though and the front fender is wierd. but for some reason i still like it
#179
Frame
Tubular steel Trellis frame
Wheelbase
1455 mm / 57.28 in
Rake
24°
Front suspension
Marzocchi 50mm fully adjustable upside-down fork with DLC
Front wheel travel
165 mm / 6.5 in
Front brake
2 x 305mm semi-floating discs, radially mounted Brembo Monobloc calipers 4-piston, 2-pad.
Front wheel
5-spoke in forged light alloy 3.50 x 17
Front tyre
120/70 ZR 17
Rear suspension
Progressive linkage with fully adjustable Öhlins monoshock. Aluminium single-sided swingarm
Rear wheel travel
141 mm / 5.6 in
Rear brake
245mm disc, 2-piston caliper
Rear wheel
5-spoke forged light alloy 5,50 x 17
Rear tyre
180/55 ZR 17
Fuel tank capacity
12,4 l - 3.3 gallon (US)
Weight *
177 kg / 390 lbs
Seat height
845 mm / 33.27 in
Instruments
Speedometer, rev counter, clock, maintenance schedule, oil temperature, oil pressure warning light, battery level, fuel reserve warning light, trip fuel, indicator light, neutral light, injection system diagnostics, lap time memory storage, automatic light-off function after 60 secs key-on, immobiliser. The instrument panel menu functions are controlled from the left-hand switchgear.
Warranty
2 years unlimited mileage
Body colours (frame/wheels)
Red (red/black)
Versions
Dual seat
* = The weight excludes battery, lubricants and, where applicable, cooling liquid.
ENGINE
Type
L-Twin cylinder, 2 valve per cylinder Desmodromic, air cooled
Displacement
1078 cc
Bore x Stroke
98 x 71.5 mm
Compression Ratio
10.5:1
Power*
90 hp - 66 kw @ 7750 rpm
Torque*
76 lb-ft - 10.5 kgm @ 4750 rpm
Fuel injection
Marelli electronic fuel injection, 45mm throttle body
Exhaust
Lightweight 2-1-2 system with catalytic converter and lambda probe
Emissions
Euro3
TRANSMISSION
Gearbox
6 speed
Ratios
1st 37/15, 2nd 30/17, 3rd 27/20, 4th 24/22, 5th 23/24, 6th 24/28
Primary drive
Straight cut gears, Ratio 1.84:1
Final drive
Chain, Front sprocket 15, Rear sprocket 42
Clutch
Dry multiplate with hydraulic control
* = Data calculated using an inertia dynamometer
close[/align][/align]
