wooohooo
will do but as of now i can tell you for som reason there is a freaking drill bit in the kit what in the world am i supposed to do with that ll
I just installed the 2009 kit. The drill bit is for removing the plug over the mixture screw. There were no instructions to drill the slide in the new kit. Also, the bit in the new kit IS MUCH TOO BIG for the slide mod discussed on previous models. It's a 5/16" instead of the 7/64" bit used for the slide.
Do not confuse the bit that comes with the DJ kit as the one you should drill the carb' slide with. It's far too large and will end in having to purchase a costly replacement slide.
The bit for the slide mod is 7/64" or the metric equal.
Always read the instructions.
