Won't start after cam mod
Hello everyone. I just did Marcelino's cam mod on my 09 klx250s and after reassembly it won't start. I even repositioned the ACR to almost exactly where it was originally located.
Everything is set exactly like the picture in Marcelino's thread and I quadruple checked that the crank was at TDC. Now, for some reason when I tried to start it the first time (without repositioning ACR) I had gas pissing out of my carb bowl overflow and when I pulled everything apart there was a significant amount of gas in the carb to filter boot. After pulling my carb and cleaning it, it no longer flooded. However, I still can't get the bike going.
The plug is wet after I crank it. I tried a new plug, nothing. I do have spark. I left the rear of my carb open just to see what is happening and when I turn it over, it seems as though my carb is blowing gas back out?
I will admit that I'm not the most knowledgeable person when it comes to four strokes, although I am familiar with it and I've rebuilt many 2 stroke engines...There are no cams to deal with in that situation though.
Do you think I screwed up the mod, or is there something else related to my carb problem that coincidentally happened after I finished? The cam sprockets are exactly as pictured, with the cam shafts in the same position at TDC. Hopefully someone can help me with advice. I wanna ride!
No, the exhaust is discharging light puffs of smoke as it turns over. But I am not actually getting ignition. The back of the carb is arbmost like it is pulsing in and out. I also see the carb moving back and forth with each stroke.
from what i read a few months ago on this cam mod, the acr must be repositioned .. also, did you modify the exhaust and intake.. if so, you need to ofset the acr.. like in the writeup. have u gotten it started yet?
