Wiring help! Aftermarket fender eliminator with turn signals.
*** SOLVED***. 10amp fuse under seat. Hey guys. I bought a cheap eBay rear fender for 2009 KLX250s. Well, you definitely get what you pay for. No wiring instructions, and it required all sorts of modifications to fit. I finally have it figured out (I think) but not before I think I blew the fuse for the rear running light. I think I blew the fuse or otherwise screwed something up. If I put a rubber band around front brake lever, brake light is working. If I touch the running light wire to it, it lights as well. But the red wire from the bike that should be the rear running light is not working. I’m not getting any juice from it. About to test the ground individually so I know it’s definitely not that. Do you guys know if there is a fuse SOLELY for the running light, and if so, where it’s at?! I hope I didn’t blow a relay or something in the bike.
