Will a new 15t sprocket improve the speedometer accuracy?
Old 03-12-2012 | 09:55 PM
Brieninsac's Avatar
Default Will a new 15t sprocket improve the speedometer accuracy?
I was reading some older posts about the inaccuracy of the speedometer. What caught my attention was one guy who put on a 1-tooth larger front sprocket on a ZX9R and that improved the speedometer accuracy.
I'm planning on switching out my 14t for a 15t. Has anyone noticed improved accuracy after doing the same?
Old 03-12-2012 | 10:38 PM
LikesToThump's Avatar
how would that make sense? hall effect is read from the front wheel.
Old 03-12-2012 | 10:51 PM
Won't make any difference on this bike.
Old 03-12-2012 | 10:53 PM
Blackheart58's Avatar
It makes a difference on my CB919, as the speed is read from the transmission. As stated before me, it's off the front wheel on our bikes. An extra tall front tire does make a difference on ours, though...
Old 03-12-2012 | 11:19 PM
ahnh666's Avatar
i switched to 15t front and switch back to stock...my speed is off by -2 mph at high speeds of about 75 mph to 85 mph....(compared to my gps speedo)...but, i'm riding a 2009 klx250sf....sm wheels....maybe my bike is just off by -2 mph if sprockets don't make a difference....i know the gps speedo is accurate...
Old 03-13-2012 | 12:34 AM
crazy we live in a world where satellites can clock or velocity better than our own bikes ;-)
Old 03-13-2012 | 02:21 AM
cmott426's Avatar
I have the 12oclockLabs Speedo Calibrator and it works great. It is "Plug-N-Play".
SpeedoDRD
Old 03-13-2012 | 02:26 AM
Ckahleer's Avatar
Changing sprocket size will not help, as the speedometer works by monitoring the RPMs of the front wheel.
A taller front tire will slow down the wheels RPMs, but it would have to have a circumference 10% greater than stock. I doubt you could find one that big.
If you want an accurate speedometer, I would reccommend the 12oclocklabs calibrator for about $70.00.
Craig
Old 03-13-2012 | 03:26 AM
durielk's Avatar
Try putting the rear wheel on the front, that should change it a little. Looking forward to your solution as my speedo is off also.
I was thinking of taking the cover off the speedo & just rotating the needle a little also.
Old 03-13-2012 | 03:38 AM
This is a funny post right? Haha?
Quick Reply: Will a new 15t sprocket improve the speedometer accuracy?
