Who's Running Front Rim Locks?
Old 06-10-2013, 11:27 PM
zippets's Avatar
Default +1
It lets the stem move a little rather than tearing it out of the tube. A tilting stem is an indication that the tire is rotating on the rim and might tear the stem off the tube. Talcum powder inside the tire and on the tube helps the two move indepentendly when/if the tire moves on the rim.
you beat me to it
Old 06-11-2013, 02:05 AM
MaximusPrime's Avatar
Well, I'll go fix that then. Learn something new every day. Thanks.
Glad my rim locks are rock solid I guess.
Old 06-11-2013, 03:03 PM
Ranger Ron's Avatar
Originally Posted by IDRIDR
Do tell more. Sheet metal screws through the rim into the tire?
They are 8-32 stainless with the ends ground to a point. I drilled and tapped the rims. The screws go about 3/16" into the beads.
Sheet metal screws were commonly used back in my desert racing days (about 150 years ago). I might have used them on the KLX if I could have found some stainless ones.
Ron
Old 06-11-2013, 03:06 PM
TNC is offline
Ron
But Ron...it was a lot easier to install those sheet metal screws in the wooden wheels you guys were using back then. These allow wheels today are a lot tougher.
Old 06-12-2013, 03:35 PM
Ranger Ron's Avatar
I said sheet metal screws, but I misspoke. I meant wood screws.
Ron
Old 06-12-2013, 09:22 PM
MOAC Man's Avatar
Rim locks? Not me...
Rear
Front
Ron
Nice one Ron.
Old trials trick.
Works perfectly. Use S/S screws like it would appear Ron has.
Howard.
dan888
09-09-2011 08:53 PM
DJFields
11-13-2007 05:44 AM
double d6
03-28-2007 07:06 PM
Nobrakes
07-16-2006 11:42 PM
sullydirt
05-05-2006 06:12 AM
Quick Reply: Who's Running Front Rim Locks?
