Where to Get Molybdenum Disulfide Grease
RE: Where to Get Molybdenum Disulfide Grease
LOL! I know. If I wasn't aware of what forum this is, I might have thought we were working on the Space Shuttle.
The high temp bearing grease should suffice for any non-engine bearing on the bike. Bearings like those in the headset, swingarn, etc don't really reach very high temps so I doubt they would tax any blead of bearing grease all that much. They just need something with good lubricating properties thay will aslo displace water.
ORIGINAL: MaverickAus
Jeez you guys sometimes overthink things, just use HTB (high temp bearing) grease
here's the link to autozone's item, remember the picture is wrong it's called premium now not industrial and this cost me $3.99 pplus tax in store:
http://www.autozone.com/autozone/acc...er=561753_0_0_
*update: also just learn something significant. moly grease and paste are 2 different things and it is important you know when to use which. the grease like this coastal stuff coedntains 1% moly, the honda pro 60 (very popular and sought after) is 60%moly. moly itself I think is crumbly so depending on useage for ..whatever this is really confusing ****. basically if the manual says use grease use moly grease, if it specifically says paste use paste, like for the gears in the engine when youre doing timing. you can get the honda moly 60 on amazon or ebay for $12, it's really really sought after for honda bikes because they have some swingarm issue or whatnot and AR15 owners are stressed out even more than we are because it's a milspec requirement, man this **** is confusing
FWIW, guys, don't use the grease which has the grey-ish "powdered" moly in it. Bad, bad, bad, especially for U-joints and wheel bearings. The powder will cause galling. Use stuff that has been fortified with liquid moly. I will not get into brand name-dropping here, but there is a difference. This is not a "Jeff's been brainwashed by some salesman" thing; there's several reports out there on the web.
Moly grease isn't for everything, as some have already stated. It's not the best for wheel bearings and many other rotating bearing designs. That's where the many wheel bearing greases are really applicable, and on things like off road and boating use, marine grease is probably even better. Just make sure it has high temp ratings for disc brake application...the good marine greases do. Moly grease is more suited to things like where two sliding surfaces interface like the splines in a driveshaft, suspension ball joints, etc. It's not the best for bearings. And while our needle bearing suspension pivots don't rotate like a wheel bearing, multipurpose greases and especially marine greases do a better job of lubing those needles and getting down into the crevices contained in a needle bearing. Moly grease doesn't migrate as well and can leave some tiny spots somewhat unprotected in a needle bearing unit.
Even though this link is from a trailer site, it has a fairly decent description of grease types and applications. Some kind of grease for any application is better than no grease at all, but there are preferred applications that work better.
Old thread or not, there's lots of confusion about the kinds of grease and where they should be applied. Over the years, I've used marine high temp wheel bearing grease for just about everything on a bike like the KLX. They are exposed to more moisture because of their use and environment, and they often don't have as robust a seal design at all possible points of water entry as some automobile applications. Moly grease is actually a little more specialized than many of the other greases out there IMO.
Overview of Lubricating Grease | etrailer.com
Penrite Moly Grease Tub - 500g - Supercheap Auto Australia
Thats what i got from my local super**** auto. Hope its fine for the head bolts.
I use the (purple) Polaris Premium All-Season Grease on pretty much everything on my sleds and bike. It is an all temperature, highly water-proof grease, which is recommended for virtually all the bearings on my snowmobiles (skid wheel bearings, drive shaft bearings, etc.). I have used it on the sleds for many years. With all the water they see, I've never had an issue with bearings rusting or seizing. It's around $9 for a large grease-gun tube...
MSDS here: http://www.purepolarisoil.com/msds/P...0_0138_(1).pdf
Looks like it is NOT Moly-based...
Ek, my personal preference (at the risk of starting a quasi oil-name dropping thread) is Schaeffer. I met with the rep a couple years ago, and we did the Timken bearing test on site. He put metal roller bearings in the machine, and we applied several name-brand greases (edit---individual tests) to the friction edges. I put most of my weight onto the machine to induce a load on the bearings. Some of the big name brands showed obvious signs of galling and began to smoke! Then, we put some Schaeffer grease on the bearings. Seriously, I put a heckuva lot of my weight on those things, and could NOT induce any wear. It's pretty impressive when it's right in front of you. I use their greases and gear lubes (tranny, diffs) and love that stuff. Lubrication Engineers makes some great products, too. No doubt, Amsoil does, as well. OK; no more name-dropping.....
