where do my cables go?
Ok so a couple months ago I took apart the front end to clean up and grease my stearing bearings. Well I'm trying to get it back together but I don't remember how my clutch cable and throttle cables were routed threw there. Does anyone have a picture or can explain where they route threw. Thanks
btw its an 07
btw its an 07
I don't know if this helps, but a year and a half ago I did the same thing. Here are some pics, if you can glean anything from these then please do. Otherwise there will probably be someone on here that can also help.
Yeah I took the bars off so i removed all that. So is the clutch cable coming up on the left side by the frame then comes up by that little hook that holds the throttle cables. Then thats where I am trying to figure out if it goes between the frame and black headlight cage and which side it comes out looking down towards your speedo
Mine follows the route from the ring guide on the radiator guard snug next to the frame around the headtube and pops up under the speedo, between the black headlight frame and the speedo cable. Clear as mud.
This should help.
This should help.
