where can I order the front sprocket?
Someone said the sunstar 13t. front sprocket was an exact fit (part #34213)dose anyone know where I can order it from? web site,or a phone number, or any other sprocket that is an exact fit.. any info would be great..
RE: where can I order the front sprocket?
www.sprocketcenter.com email or call brain he is great with answering your questions. I will never buy sprockets or chains from anywhere else.
AFAMpart # 24502 perfect fit it for a 88' to 06 EX 250 NINJA
http://www.afamusa.com/sprocket-apps...cket-apps.html
Dual Star does not have the sprockets, I just emailed them last week:
Hello,
Yes, the KLR 650 LED taillight will work in the taillight housing of the KLX250S. However, this is unofficially confirmed and is not supported by the manufacturer yet. If purchased, you are on your own. The price on the LED taillight is listed on our website at $64.95, and a 108 link RK X-ring chain will run about $77.90. The sprockets are not available to us yet, but check back periodically for updates on this matter.
Hello,
ORIGINAL: mrphone
Hello,
Hello,
Trust me, the LED tail light assembly Dual Star sells for the KLR650 (made by a company called Brake!) is a perfect fit the the KLX250S tail light. It is far and away the best LED setup I've seen for a bike. So much brighter than stock (from all angles, not just from behind) and it GETS THE ATTENTION OF CAGE DRIVERS BEHIND YOU! Plus is saves precious watts for other gadgets.
