What type (brand) of bar risers?
nah, it's the bike. also since the bar mounts don't use any kind of rubber isolation, fat bars may feel a little bit too rigid in rough terrain. If you cut them short for the trees it's even worse (my buddy's kdx) Toughest 7/8 bar I've found is pro taper.. Bent a couple of 7/8 Renthals on the klx without much of a crash, pro tapers 7/8 has been hanging in there.
I was very uncomfortable standing on the stock pegs as well. IMS footpegs were the very first mod on my new KLX.
Those risers look slick. I really like my Protaper SE KX bend bars but would like some additional height. My arms are fully out-stretched when standing on the pegs.
I am very happy with the Protaper CR Hi-bend bars. A little higher than stock and a bend that took me only minutes to get use to. I am happy with the quality & look of my Zeta barkbusters and shields; not sure about their risers, I would expect similar quality.
I have these 30mm risers on two of my bikes and I'm still using stock bars and cables, with some minor adjustments, of course. ![Big Grin](https://www.kawasakiforums.com/forum/images/smilies/biggrin.gif)
Tusk Handlebar Riser Kit | ATV | Rocky Mountain ATV/MC
Thanks.
Yes, I have these on my '07 KLX. I actually had to do the most "minor adjusting" with the clutch lever/cable and the brake lever/resevoir when I put on the handguards. IIRC I adjusted the throttle cables at the carb to get the slack I needed. I put the risers on at the same time so most of the "tweaking" was already done.
Yes, I have these on my '07 KLX. I actually had to do the most "minor adjusting" with the clutch lever/cable and the brake lever/resevoir when I put on the handguards. IIRC I adjusted the throttle cables at the carb to get the slack I needed. I put the risers on at the same time so most of the "tweaking" was already done. ![Big Grin](https://www.kawasakiforums.com/forum/images/smilies/biggrin.gif)
Thanks again,
My ROX fit right on...great things
