What size of Kenda Trackmaster K760?
tires are sized by width/section height (in percentage of width)/and finally rim size. so a 110/90 is taller than a 110/80, duh. but also a 120/90 is taller than a 110/90, because the width has changed, and so has the section profile with that. if you want lower gearing, try a 110/80(worn out, felt like i had a 13t cs on), for taller, 120/90 or even 130/90 will do just that (did 90 with 130/90).
Wider = taller???????? huh?
I just got new skins on my cycle today. I went from a 120/100 on the back to a 4.60, which should be about a 110/100. And if anything, this tire seems taller, not because it really is, but because its rounder when installed and inflated, making it appear taller. my 120/100 was flatter.
OK, I'll check that out. Thanks
Just looked...
Its because the width and aspect ratio intrude on each others terriroty, thats why........thats effin stupid. No wonder I didn't get it. I thought width meant width...silly me.
I like the American system, its 4.5 inches wide, 18 inch rim. Which makes no sense in a metric cuz is 110/100 - 18. Mixing metric and American. Who the hell comes up with this ****?
Just looked...
Just looked...
Just looked...
Thanks for all your help! Unfortunately my sister lives in London.. :-) I ordered the k760 for the rear in 110/100 (have tube for this size) and the Scorpion XC MX for the front. Got a Klim Baja pants and I got very jealous so I had to get some stuff for me too.. :-)
I know he's going to change the chain and the sprockets very soon. Thanks!
Jason, if I understand the two tier metric system, width is width. That first number is the actual width in millimeters. The second number is the height of the tire measured by the percentage of the width. So my 100/100 rear TrakMaster is 100mm wide and 100mm tall. A 120/90 tire would be 120mm wide and 108mm tall. At least this is the way I understand it. And frankly I've found the two tier metric system to be more consistent than the "inch" system. I've seen one tire in a 4.50 that was the equal of another's 5.25...and similar comparisons.
You guys wanna hear something that i think is really stupid. My father in law just got a suzuki boulevard C50T cruising bike.
Next to my KLR.
Ok its a suzuki right, jap bike. They also make a c90 and m108. The numbers are the motor size in cubic inches. Why in the hell does a metric bike have an american standard motor displacement????
Next to my KLR.
