what price should i be charged
Old 02-18-2009 | 06:31 PM
Brewster's Avatar
Originally Posted by fgk228
so my question is, is it worth it just to take it to a mechanic or sit down with the book and pull the engine apart.
There are no special tools needed to do the job so GO FOR IT!
Ride on
Brewster
Old 02-19-2009 | 07:48 PM
fgk228's Avatar
right...well anyways, found i have an oil leak...engine will turn over wih new oil in it but wont start...this sounds espensive ohh well
Old 02-19-2009 | 07:50 PM
fgk228's Avatar
expensive*
Old 02-20-2009 | 07:08 AM
fgk228's Avatar
bike is fixed, new oil...and some f***ing with the fuel tap to get it to work...thanks guys for ur help...then new oil i think has stopped the noises so i think it is fixed
Old 02-20-2009 | 03:03 PM
Just to make sure I follow ... you had an oil leak which ran your bike dry of oil and it eventually seized, is that right?
Even if it runs now, I'd be seriously concerned about internal bearings and cams. Running it dry until it seized surely did a lot of damage, even if you can't see it.
This is why you gotta be careful of used bikes, you just don't know the history.
Good luck with it, hope its OK.
Old 02-21-2009 | 06:12 AM
fgk228's Avatar
didn't completely seize because it would still turn over just very slow, main bearings wouldn't of been damaged, Monday doing a compression test...so if worst comes to worse ill need new rings and a bore done
Old 02-21-2009 | 06:14 AM
fgk228's Avatar
but the fuel tap is very annoying..no reserve
Shep
06-15-2009 12:29 AM
Worlok14
01-23-2009 01:37 PM
Fourty2ri
09-20-2008 12:13 PM
shinobi636
12-05-2006 10:28 AM
txredneckmedic
03-07-2006 04:37 PM
Quick Reply: what price should i be charged
