what options do we have for new levers?
Old 03-29-2009, 04:21 PM
tucaz#2's Avatar
Default what options do we have for new levers?
i have bent the clutch one a couple of times and yesturday bent the brake one prety good. i've been able bend them back nice and slowly each time but was wondering whats out there for when they dont bend back.
Old 03-29-2009, 04:38 PM
CousinLarry's Avatar
My findings - stock Kawasaki replacements are the only things that will work 100%. There's aftermarket levers that will work, but the brake one won't trip the brake light, and the clutch one won't pull the switch that says the clutch is in - meaning you'll only be able to start the bike in neutral - annoying.. Also - with the brake lever - the piece of metal that trips the brake light also keeps the lever from swinging forward..
So, if you want to keep the functionality, get factory replacements.
Old 03-29-2009, 06:36 PM
tucaz#2's Avatar
not to worried about the brake light. rear brake would still trip the light. starting in N could be a bit of a pain but workable.
Old 03-29-2009, 09:52 PM
cliffsta's Avatar
Just disable the clutch safety switch. When I broke my lever the day I got the bike, I accidentally broke the safety switch while replacing the lever anyway. Just jump the wires together and seal it up tight with electrical tape and goop of some kind. Start it in gear all you want, just make sure the clutch is in or you'll get a bit of a jolt
Old 03-29-2009, 11:13 PM
c_m_shooter's Avatar
The stock levers are pretty cheap, keep spares. You could add a set of bark busters if you think you are going to keep going through them at the current rate.
Old 03-29-2009, 11:22 PM
bschoolz1's Avatar
Default levers
just ordered a stock clutch for 6 bucks from local dlr after market one was $9
Old 03-30-2009, 07:06 AM
MaverickAus's Avatar
One word for ya .... BarkBusters
Old 03-30-2009, 05:03 PM
wild will's Avatar
http://www.zeta-racing.com/controls/pivot/index.html
I found these surfing around.
They fold away on crash and they make them for the KLX250s & D-tracker. I think they are $50 each though?
Zeta makes all sorts of cool stuff for the KLX & D-tracker too.
Old 03-31-2009, 12:34 PM
jsac's Avatar
hint: get some brand of barkbusters.. you wont bend anymore levers ;p
Old 04-01-2009, 12:38 AM
creamcheese's Avatar
Default Zeta Pivot Levers
Fit into your stock perch, brake lever has a post to activate brake light switch. CNC aluminum,adjustable reach , 3 finger length .
Quick Reply: what options do we have for new levers?
