This is What Happened This Morning...
Ok soooo my paranoia tells me to check the valves since I am overdue. I waited because im doing the 351 and figured i be in there any way so I would do it then. I get the body work and seat off... But the tank Right side bolt off center bolt off left bolt the encapsulated or molded in nut is spinning:eek1 Dam you Murphy... why me!!
Any suggestions??
Any suggestions??
When you turn the engine over by hand(I'm assuming that you are using the bolt on the l/h s on the back side of the crank) it should have moments of resistance and then slack as the valve open and close during crank rotation. Based on the sound from the vid I would suspect that there is a problem with the overrun clutch on the flywheel. Pull the cover for the idler gear and see if the gear on the flywheel will spin in both directions-it shouldn't.
Next step I guess is to open up stator side cover and see whats what!
Remember cheaper and easier first. Don't just jump to conclusions and open up the engine. You really need to bump start it to see if its a mechanical issue or an electrical issue. Once you determine the motor WILL fire, you must go and replace the battery. Problem still not solved? Check the wiring of your new starter, perhaps a bad ground etc.
As you can see, without preliminary testing, opening up the motor tells you nothing.
At this point I would put the stator cover back on with the idler gear in place. Leave the inspection plug on the crank bolt off and try to start the engine. If the starter clutch is working you will see the bolt spinning behind the cover and can use that info to rule out a problem with the starter drive. Like Matt said, you need to rule out the simple things.
OK, I went back and listened to your video again and it seems like it tries to bump up against compression at the very start of each attempt and then when it hits resistance it slips-I would bet that when you put the stator cover back on and try to start it you will see that the bolt is NOT spinning when the starter engages.
I would suspect that the sprag assm on the starter clutch is fubar.
The KLX has a starter clutch mechanism, sounds like the starter motor is running to me. The paws on the clutch mechanism are not working. You need to pull the clutch cage off and investigate this mechanism, or load it into the trailer and take it to the shop.
Ok after putting everything back together and no change (better or worse) I called it quits.
So last night I checked my equipment for accuracy and function....all good!
So this is what I found... battery good, starter motor good, All wiring good. I stopped there to see if anybody posted more info or ideas and to revisit what was said: and as im looking up what to call that gear between the started and the big ring behind the balancer it hits me! That gear is called a "starter idle limiter" Holy shyt!!! did I just read LIMITER I never figured that for some type of clutch mechanism. I actually went write past it and saw on the diagram the one-way clucth, one-way clutch gear comp., a coupling and a bolt all which is behind the balancer.
Out to garage swap out the starter idle limiter and thumbed the starter and
BAM
FIXED!!!!!!
Thanks all for helping out!
BAM
FIXED!!!!!!
BAM
FIXED!!!!!!
BAM
FIXED!!!!!!
Rock on!!! Glad you got it figured out!
