What is the coolant flow direction on the KLX250/300?
Old 05-08-2020 | 06:30 AM
BigBadLou's Avatar
Question What is the coolant flow direction on the KLX250/300?
My assumption is that the water pump is a puller style and thus draws cooler liquid from the right radiator and pushes it into the head. Then the hot coolant exits on the left side of the head and enters the left radiator.
Does that sound right?
I did a search not only here but also in Google and could not come up with an answer.
Who can set me straight?
TIA
Old 05-08-2020 | 08:49 PM
1994klr250's Avatar
Yes, that is correct, remember the coolant is it's at it's hottest point when it leaves the cylinder head. That's why there is a thermostat which opens when the coolant gets hot.
Old 05-09-2020 | 12:27 AM
BigBadLou's Avatar
Right. But since the KLX300 does not have a thermostat. I wanted to verify that there wasn't anything non-standard on the model. Most folks here have the 250 which came with a thermostat.
Thanks for the confirmation. 👍
Old 05-09-2020 | 10:35 PM
durielk's Avatar
How does the 300 work without a thermostat, that seems really odd. I think I would put one in, especially considering how cold blooded the KLX is.
Old 05-10-2020 | 09:38 PM
BigBadLou's Avatar
I read here that the 300 model did not come with a thermostat,
When I checked the parts diagram, I did not find a t-stat for my 1999 model.
Old 03-30-2024 | 10:52 PM
myklmesh's Avatar
Default Coolant
I have very limited mechanical skills, so I am here. I have a 2024 KLX 300 here on St. Croix, it was shipped from Miami. I need to add coolant but am not sure what to use. I went to NAPA today only to find that there are many different types of coolant, any suggestions on what I should use?
Thank you!
Mike
buerkletucson
08-22-2016 06:49 AM
Richard Avatar
03-06-2014 01:38 AM
alexgg
10-01-2013 01:53 AM
chainslack
02-26-2013 11:05 PM
timk
02-10-2006 08:07 PM
Quick Reply: What is the coolant flow direction on the KLX250/300?
