What the $%#@ front sprocket?!?
Yup, she's on there alright. I personally don't like the thought of transmitting the shocks from an impact wrench into the transmission, so I opted for a 36" cheater bar. It's still pretty stubborn though but if you lock up the rear wheel you'll eventually get it.
As mentioned above, anti-seize helps with subsequent removals.
I think in most cases, people get into trouble with air impact wrenches during installation of fasteners...too much torque applied too long.
Whew thanks for the advice guys you really boosted my self esteem lol. I was beginning to think all these years I thought I was good at fixing stuff was just a huge lie. I thought a cheap pot metal nut like this would come off easier. I'll try air impact once I find one I can use lol. At this point I might have to grind her off because the nut has taken a real beating.
Oh and I will definitely use antiseize. I've had so many problems with bolts on bikes I've been starting to use it all the time. Only problem is this silver anitseize stuff my dad has in the garage gets everywhere and is a real female dog to clean up
I sleep better not using impact wrenches on hardened steel components like those found in a transmission. Although I acknowledge that impact sockets themselves are hardened.
I am not a mechanic, I just apply the logic I learned in Geology 101: Hardened minerals resist wear but are brittle, while softer materials resist impact better due to their ductility...
the nut on mine needed to be removed with a serious air-impact wrench, the harbor freight electric one didn't do anything. even with the air-impact, it took more than 10 seconds of pressure before it popped. good luck buddy!
I used $200 something dewalt electric impact came right off
but maybe I was using the correct socket when doing it
sometimes a trick is to tighten slightly, then reverse
dont know why but it works alot on tight parts
or heat with a little torch carefully if it has any threadlock on it then impact it out
Dang! And I thought breathing on it was what finally loosened mine up...
