well, guess it's my bikes turn to visit the shop
luckly, nothing too major. one of the fork seals is leaking and the helmet lock doesn't lock.(not that i use it, but it's just the principal)
guess i've been lucky up until now. these are the first repairs, besides the ones i've caused. (like bent bars, etc) hopefully it won't take the shop forever to get it back to me.
RE: well, guess it's my bikes turn to visit the shop
ORIGINAL: klxstiffler
Keith, that seems odd that your forks would be leaking already on a 2006 model... Do you tie it down alot on a trailer or in a truck? do you jump it alot? just curious...
no, it's definatly not from strapping it down bc i use a piece of wood between the tire and fender to keep them from compressing.
it's probably from all the sand down here. it's not leaking bad. after every ride there is a ring of fluid on the tube. i've read about cleaning the seals out with a film negative or tear off from googles, but since its under warranty, hopefully they'll just replace it.
keith
keith
keith
keith
When my bike was brand new my fork seal were leaking. They fixed it with no problem. When they took the forks apart they found a little piece of plastic in there. They said when it was assembled in the factory it must got caught in their. Someone else in this forum had the same problem as me but I don't remember who.. When they replaced the fork seals they also replaced the front brake pads because they said the pads could have become contaminated with fork oil and why take a chance! Everything was covered under warranty[sm=smiley20.gif]
Interesting. I was reading just the other night where there might be an issue with "foreign matter" left in the front forks of some bikes. Seems as though there was a new worker and no one told me he had to remove a piece of tape from each set of forks before assembling them.
ORIGINAL: onestarr99
As far as tying down the whole way, I know some ol' folk who have done it forever and never 'blown' a seal. The pressure builds up when compressed but doesn't stay built up, it leaks through a hole...kinda like a shock. It's there to dampen the spring, not be the spring. It's not sitting there at 40 psi when compressed for a period of time, it goes back down. Tie it down and after a minute open up the top vent hole...it won't blow out. IMHO.....
firstninjabike
05-21-2007 06:42 PM
DevilGirl
Joke section!
03-21-2007 08:02 AM
