Watching coolant w/ radiator cap off
Old 03-05-2014 | 02:31 AM
Richard Avatar's Avatar
Default Watching coolant w/ radiator cap off
I thought I'd check my coolant flow and once the thermostat opened up there was a slight up and down pulsing of water in the radiator neck but nothing spectacular..
I've read here that the water pump doesn't pump a lot of water
What should I be seeing? Anything more than the pulsing?
Old 03-05-2014 | 02:45 AM
Yeah, it's not whitewater rapids in there for sure. It's a small water pump...not a lot of velocity but still quite effective.
Old 03-05-2014 | 02:49 AM
Well I just ordered a new thermostat since it take 1-2 mos to get here.
So there's no coolant current really visible then, just a little diaphragm-like pulsing?
Old 03-05-2014 | 02:53 AM
Hmm looks like the KLR650 thermostat is the same piece, and there's a few of them in town including a guy who uses them on guided tours.
He may know where to get one, just so I can have the piece of mind. I can use the ordered one as a backup anyway
Old 03-05-2014 | 04:15 AM
Not sure I'm understanding you. If the system is full of fluid, you should see fluid through the opening at the cap...and yes, it's usually just a kind of pulsing or small "ruffling" of the fluid visible in the cap neck.
Old 03-05-2014 | 04:46 AM
Guess my use of 'diaphragm' was midleading, sorry. The system is full.
The pulses look more like liquid that's being pumped by a diaphragm rather than flow created by a spinning pump. Though I know of course it is a spinning pump doing the work.
Ok then, I guess the slight up and down pulsing I am seeing is normal. Not much going on in there visually, but had to ask just in case
Thanks!
Old 03-05-2014 | 06:21 PM
Klxster's Avatar
I want a life where I can remove the radiator cap and ponder the intricacies of coolant flow ... NIRVANA!
Old 03-06-2014 | 12:38 AM
ol'klx-er's Avatar
Talking Count me in
Me three!
Downs3
04-02-2015 12:32 AM
alexgg
10-13-2013 08:38 AM
RenascentMisanthropy
04-01-2012 12:22 AM
punkenduro09
06-24-2010 07:51 AM
chriscrash
04-10-2010 11:59 PM
Quick Reply: Watching coolant w/ radiator cap off
