WARNING! Gas tank lock
Good day All.
( KLx250s 2007 )
My gas tank lock is not allowing me to open the tank. Can't turn the key.
I'm using penetrating oil ( 14 hours now ). And tapping on the lock. No luck.
The lock always seemed loose to the key. ( key would and does wiggle fore and aft. Never did fit in snug. )
SO! I advise everyone to go out and lube the two locking pins that hold the gas cap closed.
Sure do wish I had.
And now what do I do?
I'll keep trying. And hope for help from anyone in KLX land. Please let me know if there is a way to get the tank open or the lock to unlock.
Otherwise I'm after a second hand tank w/a key. Anyone in/near London Ontario Canada preferred. Or further away if ....
BeWell. Yours sincerely M
( KLx250s 2007 )
Sure do wish I had.
Gas cap
i think you can replace your locking cap.. with that said I would take a small flat screw driver and insert it and twist... You do have to push down on the cap a bit to free it up.. I put a small dap of grease on mine every once n awhile.. yes you will need to rekey the cap but like on my Harley give them the key # or vin
mataleao
09-03-2006 09:49 AM
