Update on merickk's 351 ordeal
I really hate to read this. I've ordered a 351 kit, and now I'm a bit nervous. I'm a woman who will be traveling alone once in a while, and I defiitely need my bike to be reliable, as I'm not a mechanic. It seems like this is probably an isolated incident, but what do you guys think?
No, I don't think this is a pattern or inherent problem with the 351 in general. I only posted the original post and this one as a point of interest for what is apparently a hard to diagnose issue with merickk's bike specifically. I wouldn't worry about this for considering a 351. For the really paranoid, however, one could stay with one of the big bore kits that keeps the water jacket intact. I think this is what Blackheart58 went with. Still, this thing with merickk's just seems to be a weird anomaly.
i know that feeling...i was ready to pull the trigger on a 351 kit this month...i'm just having trouble finding a shop that is familiar with a klx250sf and this type of work...i think i should find a dirt bike mechanic...
anyways...i'm currently doing mostly freeway riding with just a q4, k&n and jet kit...averaging about 75 mph most of the time....but, it can creep up to 80 mph to 85 mph just keep up with traffic sometimes...i'm currently riding at 7,500 rpm to 8,500 rpm constantly...installing the 15 front sprocket to help on the freeway speeds and i was going to go with a 351 for better acceleration...now, i'm having 2nd thoughts...if i should just ride it the way it is...i'm not having any problems doing 50+ mile stretches on freeways right now at about 75 mph....
Seems like the "stuck in Ouray" guy had a problem withhis coolant system that was a major contributing factor.
Bear in mind that these little thumpers have very small oil reservoirs. If you are ringing them out you need to keep an eye on the oil level. If you do that, and keep up with any losses you'll be fine.
I'd be interested in a deal on a 351 if any of you folks who have one change your mind!
Kevin
Kevin
You gotta look at the big picture. How many people have perfectly running 351 kits? I don't know for sure, but it's probably a lot.. How many people have had failures? Again - I don't know for sure, I can only name two.. This guy, and jhoffy who's was installation error..
I wouldn't let a couple bad experiences put the axe on the 351 kit when there's XXX amount of positive experiences.
My 351 kit is #9. I had a head gasket prob in the beginning, but that was due to the solid copper head gaskets they used to come with. Now they come with steel braided. Since I switched (Bill sent to me for free), I haven't had any probs. That was about 3k miles ago. I'm on about 6k with the 351 kit.
If the bike was stuck on 250cc's I'd have sold it a long time ago!
I had the 351 in for 5,000 miles plus. Zero problems. Bike had 9,000.
Bill changed to a head gasket with a fire ring a long time ago. This is a sealing ring that only presses on the sleeve and head which is what is used on most diesels with compression ratios in the stratosphere. So much for head gasket problems.
I never had an over heat problem or any other problems. I just rode the crap out of it. I traded the bike in a couple of weeks ago for a Versys. Some one is going to get a sweet KLX351SF!
david
david
Well that's what I was thinking, since it's the first time I've ever heard of a failure. I thought that the 351 was the largest bore they could make while keeping the water jacket intact. Could provide more detail on this? How is the 331 or 340 kit different than the 351 in regards to the water jacket? I understand some of the technical stuff, but I'm no mechanic.
I wouldn't hesitate to run a 351 in my bike, if I were to buy another bike some day. ESPECIALLY if you are someone that doesn't abuse the engine, I'd say don't hestitate to get the 351 Mr. Blue makes. It's not going to have a greater tendency break than any other machine, assuming it's assembled correctly...and that should be evident early on when first riding it after it's done. Even if you DO tend to abuse the engine, a 351 isn't going to be more likely to break than any other well made kit.
YMMV.
