Turn Signals
Old 07-17-2013, 05:40 PM
Pine Barrens's Avatar
Default Turn Signals
I broke my rear turn signal lens. I am looking to replace the rear signals with something that is flush-mounted/low profile (less stuff hitting the brush). Does anyone have a set-up like this or know where to look?
Old 07-17-2013, 06:01 PM
Brieninsac's Avatar
Old 07-17-2013, 08:14 PM
ITNANTI's Avatar
Default DRC LED signals
I got these after my OEM flasher was dangling in Gorman CA. So far so good and I lay this thing down once a ride at the least sorry I dont have a better close up they are the 601's.
https://www.wheelingcyclesupply.com/...ed-flashers/52
Old 07-18-2013, 12:16 AM
This site is freakin awesome! Thanks guys.
Old 07-18-2013, 03:52 AM
GBAUTO's Avatar
I had the same issue with my '12. A simple tip-over broke the lens on the turn signal so I decided to find a better solution. This is what I came up with- BikeMaster Universal Flush Mount Marker Light Kit - BikeBandit.com
The bulb faces to the rear so they are quite bright when flashing. I also transferred the shorter rubber stalks from the rear signals to the front signals to tuck them in a bit more. After quite a few 'tumbles' the lamps have been holding up quite well.
Attached Thumbnails Turn Signals-lights-001.jpg   Turn Signals-lights-002.jpg   Turn Signals-lights-003.jpg
Old 07-18-2013, 09:50 PM
Some good ideas. I like the flush mounts and the idea of the shorter rubber stalks from the rear signals to the front. I will post a picture when I get and mount them. Thanks.
Old 07-18-2013, 10:34 PM
250sf09's Avatar
K&S Universal Marker Lights - Small - Black/Amber on eBay!
I run these on my bike because of my fmf pipe, easy to install, just spliced old wiring off old directional harnesses, soldered new lights into the stock harness so that I could still use the stock connectors and not have to worry about having to splice wires or anything if I were to break one, just unplug.
Old 07-28-2013, 02:00 AM
I installed the flush mounted turn signals from Bike Bandit that GBAUTO used and also used the short stems on the front. They look good. I would love to show the pictures but I can' figure out how to post them.
Old 07-28-2013, 03:26 AM
GBAUTO's Avatar
Glad I could help-I get alot of good ideas from the folks on this forum.
Old 03-06-2022, 03:59 AM
AshCat's Avatar
how do you know what size. To order. Sorry I’m new and on my 4th set of back lights….. I fall a lot. Lol
Quick Reply: Turn Signals
