Turn signal replacement method?
Old 10-21-2006 | 04:16 AM
tennisman's Avatar
Default Turn signal replacement method?
Just wondering how folks have re-wired/replaced their stock turn signals? Are there stock bullet connectors front and back that you've un-plugged/plugged into with yer new turn signals? Or, did you cut the wire at the terminal inside the stock turn signal and add new bullet connectors at the cut?
Pics and/or advice?
Thanx, Lance [&:]
Old 10-21-2006 | 04:47 AM
STrack's Avatar
Default RE: Turn signal replacement method?
Unfortunately the stock bullets for the turn signal are an odd-ball size. The wires on the new signals I got were also too short, so I cut the old wires in about half and then soldered them to the new signals. I then put heat shrink tubing over the splice. Butt connectors would have worked too.
Old 10-21-2006 | 06:00 AM
klxCouple's Avatar
I did the same
Randy
ORIGINAL: STrack
[IMG]local://upfiles/2315/9004D51D5EE94601938E50E56C3605DB.jpg[/IMG]
Old 10-21-2006 | 01:03 PM
solder and shrink wrap... thats the ticket....
Old 10-23-2006 | 07:01 AM
ORIGINAL: EMS_0525
"Yeaaaaaa with flames shooting out of it" (From SNL)
oregon_gutter_rider
05-25-2013 02:53 AM
Grease
Ninja ZX-10R
20
01-15-2008 01:19 AM
jernierivera
05-30-2007 05:02 PM
mdc160
Ninja ZX-10R
08-31-2006 05:54 AM
NightMayor
ZZR 600
04-12-2006 08:35 PM
Quick Reply: Turn signal replacement method?
