Tubes loosing air.
Old 01-13-2009 | 02:39 PM
oldphart's Avatar
Banned
Sorry guys someone peed me off, no one, on the forum thankfully, just a butt head who now took his remaining teeth back home in a bag, cost the sucker more to pickup bag and figure out how his teeth might refit.
Last edited by oldphart; 01-13-2009 at 02:40 PM. Reason: did I mention the divorce.
Old 01-13-2009 | 08:25 PM
RaceGass's Avatar
Whatda about helium? Wouldn't that make yer bike lighter?
Old 01-14-2009 | 12:18 AM
je2000's Avatar
Originally Posted by horizonod
When I was looking at new tubes I ran into some that had a warning that perfectly good inner tubes loose air. Some loose a fairly significant amount like 3 lbs a week. I never realized that inner tubes were air permeable. I guess some are and some aren't.
Any thoughts or recommendations on inner tubes that DON'T loose air?
It's true. I was SOOO mad the other day. My dirt wheels have been sitting on the deck for over a month. I swapped out the street for the dirt setup, went for a short run in the yard. Lifted the wheel a bit. Little did I know I was probably spinning the tire.
Went down the driveway and had a flat...it would not hold any air. Problem was in the valve stem.
TCLOCS......grrr. I missed my ride.
Old 01-16-2009 | 03:22 AM
Savage's Avatar
add some kawasaki lime green slime to your tires to help prevent flats.
Old 01-16-2009 | 03:48 AM
BP88's Avatar
oldphart must be drunk.
Anyways, try looking into some Kenda heavy duty tubes. I hear they work great.
Old 01-16-2009 | 04:11 AM
horizonod's Avatar
I know tires and tubes will lose some air over time but I thought it took longer. One of the tube companies said they can loose up to 3 lbs a WEEK and that's "normal"?
I very the preasure in mine anyway depending on the ride and my compressor is 10 feet from the bike so I'm not sighting personal experience or a problem. I just thought that was alot of air to lose in aweek.
I use slime to the lament of some forumites but I think that, besides the other "benefits", slime also helpsseal against this air permiation of the tube.
Old 01-16-2009 | 04:18 AM
BP88's Avatar
The tire slime may help against air loss, but to what extent? I doubt by much at all.
Before you take the bike on a long ride, check the tire pressure. Cheap insurance that you won't be stranded.
chrisbone123
05-22-2008 05:10 AM
fireroad
07-24-2007 01:41 AM
iregula
Ninja 500R
04-30-2007 11:16 PM
dieselmech
03-12-2007 07:34 PM
rkutzner
02-16-2007 02:37 AM
Quick Reply: Tubes loosing air.
