Tubeless tyre leak
Edit- i forgot Neutech is Tubliss and thought i was describing an alternative. peace out
Bra I have the Tubliss on my WRf stock rims. System came with a glued rim strip (liner) that covers the back of the spoke nipples. Kind of like black, sticky, stretchable plumbers pipe tape. This gets additional squashing against the same nipples from the 110 psi inner-inner small, high pressure tube. Added some slime and i ride it at 10 psi in the dirt. If I had money to spare i would put them on the green machine in a flash but i don't. Great performance upgrade to the off road feel and traction that i like.
Anyone else riding tubeless tires?
I also bought a Neutech tubliss last year for the front. Tried to install it two times when changing tires, but could not have it keep the low pressure. The second time I've been as cautious as can be, following the instructions closely, but no way. I tried putting some tire sealant, was still leaking. May be I did not put enough.
Do you guys use a sealant with this system?
FYI, Trials bikes usually are tubeless, and have spokes. Learning to change a tire is invaluable. One lesson I learned is if it seems to hard physically, I am doing it wrong. There are some excellent videos out there.
How much Slime did you put there, a complete bottle?
Here's a Japanese site with a tubeless solution, pictures say it all..
http://www2s.biglobe.ne.jp/~outex/tubelesskit.htm
Ray, did you use a new tire or one with some use on it? Most new tires will hold air quite well with the Neutech deal. I do use a sealant in the tire. I used tubeless Slime in the first set of tires and am using Stan's MTB sealant in the second set. Both have worked with equal success from my experience.
Isn't there some sort of sponge rubber ball setup out there somewhere? Stuff your tires with rubber *****? Nice to do away with tubes, be even nicer to do away with air altogether...
Put the wheel beside your bike on the kickstand side. Use the extended kickstand foot and the weight of your bike to push down on the bead....takes very little effort to do it this way.
