Trailtech Vapor users
Do you have a picture of the unit lit up at night? And did you run into any problems with the sensor while going thru mud, does it stay secruly mounted and keep it's reading?
Thanks
Thanks
RE: Trailtech Vapor users
No problems at all since I got it and it has been used quite a bit. The security of the mounting depends entirely on how YOU mount it. The hardware you get with the unit is crap (IMHO) I made my own mount and it is VERY secure. These picture are a couple thousand ago, but it looks the same now as it did them.
MarkTurbo, i bought the aluminum case and modified it so the little LEDs would fit and I made the black bracket underneath it out of a old piece of 2X6 rectangle tubing cut to fit.
Kawi-speed, i will try to get some idle picks, but she is all tucked in for the night.
I have the 022-TM which looks similar to Jeeps but there is a few that look similar
http://www.trailtech.net/vapor_protectors.htm
ORIGINAL: TeamKLX250
