Top end speed
RE: Top end speed
keep the stock gears or even add 3 teeth to the rear. I wouldn't put higher gears on because the bike does not have enough power, I have the irc gp1 50 50 tire, seems to be good on and off road.
RE: Top end speed
The stock gearing setup is fine for top end. After the carb and exhaust mods it's pretty easy to get the KLX up to 85-90 but make sure you have a change of underwear with.
"It's more fun to ride a slow bike fast, then a fast bike slow"
RE: Top end speed
ORIGINAL: riccun
The best setup for a higher top end is a larger displacement bike, preferably something that doesn't grab so much air.
This bike is really unstable when you get around 80 I wouldn't try going any faster. If youdo it anyway,try a set of street tires and a supermoto front fender. That would help some.
RE: Top end speed
I recommend a set of Dunlop D607's for street and they are very stable (the front is a sportsman SM tire and the rear is a trailmax for the 18" size) and i have not experienced any head shake up to about 85mph (95 on the speedo) I have not tried to do this more than the one time I did trying to outrun a thunderstorm.besides a big bore kit I don't think it's worth trying to swap gearing to go "faster" as 1st gear simply becomes too tall for a pullout without abusing the clutch.
jhoffy22
09-26-2011 03:42 AM
